Knowledge Base Article
Error(19261): Signal pcie_rstn_pin_perst has been constrained to a location that is a dual purpose pin that can be used by the PCIe HIP as nPERST.
Description
The following error will be seen when compiling a design that includes the Intel® Stratix® 10 Hard IP for PCI Express targeting an 1SG040* device OPN.
The nPERSTL0 pin of this device package is a dual purpose and located in a 3.0 V bank.
Resolution
When using this pin as PCI Express nPERST with I/O standards of 1.2 V, 1.5 V, 1.8 V, 2.5 V, or 3.0 V LVTTL, the following assignment should be added in the Intel® Quartus® Prime Software settings file (.qsf) to disable GPIO usage and to resolve the error.
set_instance_assignment -name USE_AS_3V_GPIO ON -to pin_name
Example:
set_instance_assignment -name USE_AS_3V_GPIO ON -to pcie_rstn_pin_perst
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 21.3.
Updated 2 months ago
Version 2.0
