Knowledge Base Article
Error(18948): Error message received from device: Detected internal error.
Description
You may see this error in Intel® Quartus® Prime Pro Programmer when trying to configure an Intel Stratix® 10 device with a design that contains any of the following features/IP and the reference clocks for these features/IP are not running and at correct rates before and during configuration.
- Transceivers (including PCIe HIP)
- External Memory Interfaces (EMIF)
- Hard Processor System (HPS)
- High Bandwidth Memory 2 (HBM2)
- Secure Device Manager (SDM)
Resolution
Ensure that the reference clock required by these features is present before and during configuration, otherwise configuration may fail.
Updated 1 month ago
