Knowledge Base Article
Error(175001): The Fitter cannot place 1 pin, which is within <esram_name>
Description
You may see this error message when compiling a project which instantiates the Intel® eSRAM IP followed by information messages similar to these referring to the input ref clock :
Info(14596): Information about the failing component(s):
Info(175028): The pin name(s): <esram_refclk_name>
The reason this fitter error occurs is that the eSRAM input PLL reference clock does not have an LVDS I/O standard assignment in the project.
Resolution
The eSRAM input PLL reference clock only supports the LVDS I/O standard but the Intel® eSRAM IP itself does not include this assignment.
Add an LVDS I/O standard qsf assignment for the eSRAM PLL reference clock and place it on the dedicated input clock pins (CLK_ESRAM_[0,1]p/n) on the top or bottom edge of the FPGA.
Updated 2 months ago
Version 2.0
