Knowledge Base Article
Error(175001): The Fitter cannot place 1 LVDS_CHANNEL, which is within LVDS SERDES Intel FPGA IP
Description
You may get this error when the LVDS SERDES Intel® FPGA IP  transmitter is driven by a PLL from adjacent  I/O banks in intel® Arria® 10 devices.
The Intel® Quartus® Prime Pro Edition Software does not allow I/O PLLs to drive transmitter channels in adjacent I/O banks. This will result in additional jitter on  TX channels caused by the clock path traversing the core / cascaded PLLs.
Resolution
If an I/O bank PLL drives transmitter channels in adjacent I/O banks,  it must drive at least one transmitter channel in the same bank.
The Intel® Arria® 10 Core Fabric and General Purpose I/Os Handbook will be updated to emphasize the LVDS placement guideline as shown below:
The I/O bank PLL can drive the differential transmitter channels in an adjacent I/O bank only in the following conditions:
  • The interface is a wide LVDS SERDES Intel® FPGA IP transmitter interface that spans multiple I/O banks
    • With tx_outclock enabled—the transmitter has more than 22 channels
    • With tx_outclock disabled—the transmitter has more than 23 channels
  • The PLL also drives at least one transmitter channel in its own I/O bank
Updated 19 days ago
Version 2.0
