Knowledge Base Article
ERROR(16031): Current Internal Configuration mode does not support memory initialization or ROM. Select Internal Configuration mode with ERAM.
Description
The error above will be seen when using the FFT IP core with Intel® MAX® 10 SC devices that do not support the Memory Initialization Compact feature as the FFT IP needs on-chip memory to store coefficients. This error will be seen during synthesis when the FFT IP has instantiated in Intel® MAX® 10 SC projects.
Resolution
To work around this problem when using the FFT IP, use Intel® MAX® 10 devices that include Flash or Analog features, both of these features support memory initialization.
Updated 1 month ago
