Knowledge Base Article
Error(13224): Verilog HDL or VHDL error at <your module name>.sv(<your line number>): index <your index> is out of range [<your range>] for '<your variable>'
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.4 and earlier, you may see this error during the Analysis & Synthesis stage. This is due to the parameterized interfaces' failure to override the SystemVerilog interface localparam logic variables with the top-level wrapper variables.
In the example below, the interface localparam logic variables ADDR_W and DATA_W, with the parameters of 4 and 1, are not overridden by the top-level wrapper variables, with the parameters of 5 and 8 respectively.
Top-level wrapper:
module mem_wrapper #( int ADDR_W = 5, int DATA_W = 8 )
    mem_if #( ADDR_W, DATA_W ) mem_if ( i_clk_a );
    mem mem ( mem_if );
endmodule : mem_wrapper
Interface:
interface mem_if #( int ADDR_W = 4, int DATA_W = 1 ) ( input clk );
    localparam logic [DATA_W - 1:0] INIT_V [2 ** ADDR_W] = '{default: '1};
    modport mem ( input clk, addr, wren, idat, output odat );
endinterface : mem_if
Modport:
module mem ( mem_if.mem mem_if );
   logic [mem_if.DATA_W - 1:0] mem [2 ** mem_if.ADDR_W];
   initial
     for(int i = 0; i < 2 ** mem_if.ADDR_W; i++)
       mem[i] = mem_if.INIT_V[i];
endmodule : mem
Resolution
To avoid this error, do not use the localparam logic in the SystemVerilog interface.
For example:
Interface:
    modport mem ( input clk, addr, wren, idat, output odat, INIT_V);
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 22.4.
Updated 2 months ago
Version 2.0
