Knowledge Base Article
Error(13149): EMIF/PHYLite systems sharing a PLL reference clock do not have identical reset inputs for following io_aux atoms
Description
When you implement an Intel® Arria® 10 External Memory Interfaces IP and an Intel Arria 10 PHYLite IP sharing the PLL reference clock and reset in the same I/O column, you may see this fitter error.
Resolution
To work around this problem, tie the Intel® Arria® 10 PHYLite IP reset port to "1".
Updated 2 months ago
