Knowledge Base Article
Error: xcvr: set_port_property sets an illegal FRAGMENT_LIST for port unused_tx_parallel_data
Description
When using Arria® V transceiver devices, you may see the above transceiver Native PHY MegaWizard™ error in the following configuration when using Quartus II software version 13.0sp1:
  • Standard PCS/PMA interface width = 20
  • FPGA fabric/Standard TX PCS interface width = 32
  • TX 8B/10B encoder is enabled
  • TX 8B/10B disparity control is enabled
  • Simplified data interface is enabled
Resolution
To work around this problem you can disable the Simplified Interface option in the Native PHY MegaWizard.
This problem will be fixed in a future version of the Quartus II software.
Updated 3 months ago
Version 2.0
