Knowledge Base Article
Error: (vlog-7) Failed to open design unit file "./../../../rtl/address_decoder/address_decode/altera_avalon_st_handshake_clock_crosser_161/sim/altera_avalon_st_handshake_clock_crosser.v" in read mode.
Description
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition software version 20.4.
In Windows environment, you may find the following error message during simulation of Low Latency 10G MAC IP example design with Modelsim® when the maximum length of file path is beyond 260 characters
Resolution
To avoid the error, reduce the directory depth of simulation files.
Updated 3 months ago
