Knowledge Base Article
Error: Verilog HDL Module Instantiation error at bitec_hdmi_tx_aux_encoder.v(0): module "bitec_hdmi_aux_bch" has no parameter named "SYMBOL_PER_CLOCK"
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software v20.4, you will see this error when integrating the HDMI Intel® FPGA IP 2.0 Tx and the HDMI Intel® FPGA IP 2.1 RX into a design. This is because the module bitec_hdmi_aux_bch has the same module name between the HDMI Intel® FPGA IP 2.0 and the HDMI Intel® FPGA IP 2.1, but the parameters are different.
Resolution
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software v21.3.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
