Knowledge Base Article
Error: Verilog HDL error at altera_irq_clock_crosser.sv(21): module "altera_irq_clock_crosser" cannot be declared more than once File: <directory path>/altera_irq_clock_crosser.sv Line: 21
Description
Due to a problem in the Quartus® II software version 12.1, you may see this error during generation of Qsys systems that utilize IRQ Clock Crosser Logic.
Resolution
To workaround this problem follow the steps below:
Open the altera_irq_clock_crosser_hw.tcl file located in the Quartus II installation directory in a text editor:
<Quartus II install directory>\ip\altera\merlin\altera_irq_clock_crosser -
Remove the line: "set_module_property SIMULATION_MODEL_IN_VERILOG true"
Add the line: "add_file altera_irq_clock_crosser.sv {SYNTHESIS SIMULATION}"
Save the file and re-generate the Qsys system
This problem is fixed for the Quartus II software version 13.0 and later.
Updated 1 month ago
