Knowledge Base Article
Error: Unresolved inclusion: "altera_avalon_uart_regs.h" in Eclipse® project
Description
Due to issues in eclipse® compiler, it is not able to update the indexer. While including "altera_avalon_uart_regs.h". in a C or Cpp project, the compiler shows the following error message:
Multiple markers at this line
- Unresolved inclusion: "altera_avalon_uart_regs.h"
- fatal error: altera_avalon_uart_regs.h: No such file or directory
Resolution
To overcome this issue, you need to refresh the indexer by following the steps below:
1- Right click the application folder
2- Go to Index
3- Select Rebuild
4- If step 3 couldn’t help, select freshen All file
Updated 3 months ago
Version 2.0
