Knowledge Base Article
"Error: Unrecognized switch use-quartus-top-names" while executing ip-setup-simulation command in the Intel® Quartus® Prime Software v21.4
Description
Due to a problem in the Intel® Quartus® Prime Pro Software version 21.4, you might encounter the following error while executing command: ip-setup-simulation --use-quartus-top-names --quartus-project=<quartus_project_name>.qpf
Resolution
To work around this problem, follow these steps:
  1. Remove "--use-quartus-top-names" switch.
  2. Add "set TOP_LEVEL_NAME <top_instance_name>" in run_<simulator>.do of the IP simulation script.
This problem has been fixed starting with the version 22.1 of the Intel® Quartus® Prime Pro Software releases.
Updated 2 months ago
Version 2.0
