Knowledge Base Article
Error: <module name>The source has a data signal of <number> bits, but the sink does not.
Description
Due to a problem in Quartus® II/DSP Builder 14.1, you will see the above error on components which have more than one Avalon® ST interface (AVST).  You may also notice in the Qsys heirarchy view that one of the AVST interfaces has no signals, and that there is an extra interface named "exp" which also has no signals.
Resolution
To work around  the problem, find and edit the Qsys generated <module name>_hw.tcl file for the component in the error message.
Make the signal names unique between all avalon_streaming sinks, and between all avalon_streaming sources.  For example you can add a "1" to all the names on one component.
Also comment out the "exp" interface.
For example:
Qsys generated version:
# Interface AStInput
add_interface AStInput avalon_streaming sink
set_interface_property AStInput errorDescriptor ""
set_interface_property AStInput maxChannel 255
set_interface_property AStInput readyLatency 0
set_interface_property AStInput ASSOCIATED_CLOCK clock
set_interface_property AStInput ENABLED true
set_interface_property AStInput dataBitsPerSymbol 17
add_interface_port AStInput input_ready ready Input 1
set_port_property input_ready VHDL_TYPE STD_LOGIC_VECTOR
add_interface_port AStInput sink_valid valid Input 1
set_port_property sink_valid VHDL_TYPE STD_LOGIC_VECTOR
add_interface_port AStInput sink_channel channel Input 8
add_interface_port AStInput sink_data data Input 17
add_interface_port AStInput sink_sop startofpacket Input 1
set_port_property sink_sop VHDL_TYPE STD_LOGIC_VECTOR
add_interface_port AStInput sink_eop endofpacket Input 1
set_port_property sink_eop VHDL_TYPE STD_LOGIC_VECTOR
# Interface AStInput1
add_interface AStInput1 avalon_streaming sink
set_interface_property AStInput1 errorDescriptor ""
set_interface_property AStInput1 maxChannel 255
set_interface_property AStInput1 readyLatency 0
set_interface_property AStInput1 ASSOCIATED_CLOCK clock
set_interface_property AStInput1 ENABLED true
set_interface_property AStInput1 dataBitsPerSymbol 17
add_interface_port AStInput1 input_ready ready Input 1
add_interface_port AStInput1 sink_valid valid Input 1
add_interface_port AStInput1 sink_channel channel Input 8
add_interface_port AStInput1 sink_data data Input 17
add_interface_port AStInput1 sink_sop startofpacket Input 1
add_interface_port AStInput1 sink_eop endofpacket Input 1
# Interface exp
add_interface exp conduit end
set_interface_property exp ENABLED true
Modified version:
add_interface_port AStInput1 input1_ready ready Input 1
set_port_property input1_ready VHDL_TYPE STD_LOGIC_VECTOR
add_interface_port AStInput1 sink1_valid valid Input 1
set_port_property sink1_valid VHDL_TYPE STD_LOGIC_VECTOR
add_interface_port AStInput1 sink1_channel channel Input 8
add_interface_port AStInput1 sink1_data data Input 17
add_interface_port AStInput1 sink1_sop startofpacket Input 1
set_port_property sink1_sop VHDL_TYPE STD_LOGIC_VECTOR
add_interface_port AStInput1 sink1_eop endofpacket Input 1
set_port_property sink1_eop VHDL_TYPE STD_LOGIC_VECTOR
# Interface exp
# add_interface exp conduit end
# set_interface_property exp ENABLED true
This is scheduled to be fixed in a future release of the Quartus II/DSP Builder software.
Updated 17 days ago
Version 2.0
