Knowledge Base Article
Error: Text Design File syntax error: Text Design File contains a symbolic name, but must contain '(', Error: Node instance auto_generated instantiates undefined entity sld_ela_trigger_qdm
Description
The following errors may occur in the Quartus® II software version 4.0 when you have white space characters in a SignalTap® instance name:
    • Error: Text Design File syntax error: Text Design File contains a symbolic name, but must contain '('
    • Error: Text Design File syntax error: Text Design File contains a symbolic name, but must contain ';'
    • Error: Node instance auto_generated instantiates undefined entity sld_ela_trigger_qdm
    The workaround for these errors is to change each white space in the SignalTap instance name to an underscore character (_).
    This error has been fixed in the Quartus II software version 4.1.
    Updated 3 months ago
    Version 2.0
