Knowledge Base Article
Error (suppressible): (vsim-3058) The width (83) of Verilog port 'av_st_din_data' does not match the array length (48) of its VHDL connection
Description
Due to a problem in the Quartus® Prime software version 17.0 update 1 and earlier, you may see the error mentioned above while running VHDL VHDL-based simulation model for the Clock Video Output II IP core.
Resolution
This issue has no workaround; the user must install the Quartus® Prime Pro Edition Software version 20.2 to resolve it.
Updated 2 months ago
