Knowledge Base Article
Error-[SHARED-LIBRARY-ACCESS] Shared library access error Unable to open shared library due to the below reason /p/psg/eda/aldec/riviera/2023.10/linux64/suse/bin/Linux64/libsvdpi_exp.so:
Description
You may see the error messages while compiling  Quartus® Prime Pro Edition Softwere version 24.1 design by the VCS simulator.
This is a C model issue in libdb_gdr_fec.so file and workaround is to remove the compilation of libdb_gdr_fec.so file from compile command in sim setup script.
Resolution
You can change the following line from within vcsmx_setup.sh:
SIM_OPTIONS="$SIM_OPTIONS -sv_lib $QUARTUS_INSTALL_DIR/eda/sim_lib/libdb_gdr_fec"
To:
SIM_OPTIONS="$SIM_OPTIONS"
Additional Information
This will be fixed in future release version of Quartus® Prime Pro software.
Updated 2 months ago
Version 2.0
