Knowledge Base Article
Error setting certificate verify locations
Description
You may see this error when using git commands from a SoC EDS command shell.
Resolution
To solve this problem run the commands below from your SoCEDS command shell:
- git config --system http.sslcainfo /usr/ssl/certs/ca-bundle.crt
- git config --global http.sslVerify false
If you are using a proxy for internet access on your computer, please also set the proxy option as below:
- git config --global http.proxy <your proxy here>
Updated 1 month ago
