Knowledge Base Article
Error: SERDES DPA Block node 'lvds_rx:lvds_rx_inst0|altlvds_rx:ALTLVDS_RX_component|lvds_rx_lvds_rx:auto_generated|lvds_rx_dpa3' is not properly connected on the 'RXFCLK' port. It must be connected to one of the valid ports listed below.
Description
Due to a problem in the Quartus® II software version 12.1 and later, you may see this error in Arria® V devices when using the ALTLVDS_RX mega function in external PLL mode.
Error: SERDES DPA Block node 'lvds_rx:lvds_rx_inst0|altlvds_rx:ALTLVDS_RX_component|lvds_rx_lvds_rx:auto_generated|lvds_rx_dpa3' is not properly connected on the 'RXFCLK' port. It must be connected to one of the valid ports listed below. Info: Can be connected to LVDSCLK port of arriav_pll_lvds_output WYSIWYG Info: Can be connected to OUTCLK port of generic_pll WYSIWYG
Resolution
To workaround this problem, an LVDS buffer needs to be inserted between the external pll and the ALTLVDS instance on the rx_inclock and the rx_enable ports.
Refer to the related solution below to learn how to add an intermediate LVDS buffer between the external PLL and ALTLVDS IP.
Related Articles
Updated 2 months ago
Version 2.0
