Knowledge Base Article
Error reported by S-function 'mip_control' in 'dspba_tmpl_ip_chan/Control': Compiler Internal Restriction: 'priv->m_modelSpecificAdjustment != nullptr' [device::Device::getChainMultAddQuantum at p4/dspba/src/device/device.cpp:2024]
Description
Due to a problem in DSP Builder for Intel® FPGAs version 21.4 and earlier, you may see this error when trying to simulate a model.
Resolution
To work around this problem, enable the “Generate hardware” option in the DSP Builder for Intel® FPGAs settings.
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition Software version 22.1.
Updated 2 months ago
Version 2.0
