Knowledge Base Article
Error-[PE_CDB] Corrupted data_block. Checksum did not match for data_block in file
Description
This error may occur when calling the Quartus® EDA Simulation Library Compiler using a 32-bit version of the Synopsys VCS* simulator in the Quartus® Prime Pro Edition Software version 24.1 and earlier.
Resolution
Synopsys VCS* compilation must be run with 64-bit support. This error can be fixed with either of the following steps:
- Add the "-full64" flag to the command line, some Design Examples do this by default.
- Set the VCS_TARGET_ARCH appropriately, for example to "linux64" or "suse64".
Updated 2 months ago
