Knowledge Base Article
Error: pcie_ed.BAR_INTERPRETER.bri_master: TRAFFIC_GEN_CHECK.control_status_slave (0x120..0x13f) overlaps DMA_CONTROLLER.dma_slave (0x0..0xfff)
Description
This error may be seen during the Intel® L- and H-tile Avalon® Memory-mapped+ IP for PCI Express* DMA example design generation with Intel® Quartus® Prime Design Software.
Resolution
To avoid this error, uncheck the 'Enable bursting Avalon-MM Slave interface' option in the Avalon-MM setting to disable the Bursting Slave module. The DMA example design only supports the Bursting Master module, Read Data Mover module and Write Data Mover module enabled.
Updated 2 months ago
Version 2.0
