Knowledge Base Article
Error: pcie_av_hip_de_hip_status_0: wrong # args: should be "proc_quartus_synth name"
Description
This error will be seen when generating a testbench for the PCI Express® reference design supplied with AN456 in either Arria® V or Cyclone® V devices. This error is due to the Status Output Bridge module not having a suitable simulation model.
Qsys will report the following error if you generate the testbench with these settings:
- Create testbench Qsys system: Standard, BFMs for standard Avalon interfaces
- Create simulation Model: Verilog
    while executing
"proc_quartus_synth"
    (procedure "proc_sim_verilog" line 2)
    invoked from within
"proc_sim_verilog altpcie_av_hip_ast_hip_status_bridge"
Info: pcie_av_hip_de_hip_status_0: "top" instantiated altera_pcie_av_hip_de_hip_status "pcie_av_hip_de_hip_status_0"
Error: Generation stopped, 3 or more modules remaining
Info: top: Done top" with 7 modules, 89 files, 3559773 bytes
Error: ip-generate failed with exit code 1: 2 Errors, 8 Warnings
Resolution
For simulation, either remove the status module from the design or use another sample design available from your Quartus® II installation directory.
<your installation directory>\ip\altera\altera_pcie\...
Related Articles
Updated 3 months ago
Version 2.0
