Knowledge Base Article
Error Occurs When Running Simulation Example Design in ModelSim or Riviera-PRO
Description
When you attempt to run the UniPHY simulation example design in ModelSim or Riviera-PRO, you may receive the following error:
Error: (vsim-125) The shared library ./submodules/libbytestream_pli.so being
loaded was built on a 32-bit machine. A 32-bit shared library cannot
be loaded in a 64-bit simulation. Please use compatible machines
to build and load the library
This issue affects DDR2 and DDR3 protocols, and QDR II/II and RLDRAM II when using the Nios II-based sequencer.
Resolution
There are two possible workarounds for this issue:
- Use a 32-bit version of the ModelSim or Riviera-PRO executable.
- In a text editor, open msim_setup.tcl under
<variant_name>_example_design/simulation/verilog/mentor/ or
<variant_name>_example_design/simulation/vhdl/mentor/.
Locate the
alias elabsection and remove-pli /submodules/libbytestream_pli.sofrom thevsimline.
Updated 3 months ago
