Knowledge Base Article
Error: Node instance "" instantiates undefined entity "sld_reserved__<SignalTap II name>_<trigger number>"
Description
This error message occurs in the Quartus® II software version 6.0 and later under the following conditions:
  • You compile the design from a system command prompt
  • The design includes a SignalTap® II logic analyzer
  • No database (<project>\db) directory exists, or it exists but does not include the file sld_reserved_<project>_<SignalTap II name>_<trigger number>.v when you compile the design
Use one of the following suggestions to work around this problem:
  • Before you compile the project at a system command prompt, open the Quartus II GUI, then open and save your project. This process recreates the missing file.
  • Do not delete the file sld_reserved_<project>_<SignalTap II name>_<trigger number>.v when you delete files from the db directory.
This problem may be fixed in a future version of the Quartus II software.
Updated 2 months ago
Version 2.0
