Knowledge Base Article
Error message: "Component 'mscomm32.ocx' or one of its dependencies not correctly registered: a file is missing or invalid
Description
You may receive this error message when attempting to run the write2flash_S25_v3.exe program provided with the Stratix DSP kit v1.1.0. To avoid this error message, you need to copy the mscomm32.ocx file into the directory where you have the write2flash_S25_v3.exe file. The 'mscomm32.ocx', is provided in the "Labs/Error_Correction/Example 3" directory.
Updated 21 days ago
Version 3.0
