Knowledge Base Article
Error message: “Device <device_name> is not supported”
Description
You may see the above error message when you are attempting to read the JIC file (that was created prior to Intel® Quartus® Prime Programmer version 20.3) in Intel® Quartus® Prime Programmer version 20.3 .
Example: “Device AGFA014 is not supported”
Resolution
Regenerate the JIC file using Intel® Quartus® Prime Programmer version 20.3.
Note: Recompilation of SOF is not required.
Updated 3 months ago
