Knowledge Base Article
Error-[MCSE] Maximum class size exceeded ../22.1/quartus/eda/sim_lib/synopsys/tennm_atoms_ncrypt.sv, 15429275
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 22.1, you might see this error during the VCS simulation of the Agilex™ 7 FPGA EMIF.
Resolution
To work around this problem, remove the -partcomp VCS argument during simulation or revert to the previous IOSSM by setting the ed_sim.emif_cal.emif_cal.emif_cal.arch_inst.io_ssm.iossm_use_model parameter to 0 as described in the External Memory Interfaces Agilex™ FPGA IP User Guide
Updated 3 months ago
Version 2.0
