Knowledge Base Article
Error May Occur in EMIF VHDL Simulation with Riviera-PRO
Description
This problem affects DDR2, DDR3, LPDDR2, QDR II, RLDRAM II, and RLDRAM 3 products.
If you are using Riviera-PRO version 2012.06 to simulate your external memory interface with the VHDL simulation flow, you might encounter the following error:
# ELAB2: Fatal Error: ELAB2_0103 Input and inout ports
of type reg are not allowed in Verilog modules instantiated in VHDL.
# KERNEL: Error: E8005 : Kernel process initialization failed.
# VSIM: Error: Simulation initialization failed.
Resolution
The workaround for this issue is to upgrade to Riviera-PRO version 2012.10.
This issue will not be fixed.
Updated 2 months ago
