Knowledge Base Article
Error: IR FIFO USERDES Block node 'lvds_rx:inst|altlvds_rx:ALTLVDS_RX_component|lvds_rx_lvds_rx:auto_generated|sd2' is not properly connected on the 'WRITECLK' port
Description
You will encounter this synthesis error if you connect a PLL and ALTLVDS_RX megafunction in External PLL mode and PLL clock switchover is enabled. This error occurs because the Quartus® II software does not insert a cyclonev_pll_lvds_output atom between the PLL and the ALTLVDS_RX megafunction during synthesis.
Resolution
The workaround is to insert the following atom between the PLL and the LVDS_RX:
cyclonev_pll_lvds_output #(
.pll_loaden_enable_disable("true"),
.pll_lvdsclk_enable_disable("true")
) stratixv_pll_lvds_output_inst (
.ccout({loaden_from_pll, fclk_from_pll}),
.loaden(loaden_to_lvds),
.lvdsclk(fclk_to_lvds)
If the target is a Stratix® V device, you can change the name to stratixv_pll_lvds_output.
Updated 2 months ago
