Knowledge Base Article
Error: Internalstandard logic vector: Zero or negative width types not supported, it was 0
Description
You may see this error message during IP regeneration of an Arria® 10 Device Transceiver Reset Controller IP if you have set the Number of Transceiver Channels to 0.
Resolution
This problem has been fixed in Quartus® Prime software versions 17.0 and later. For earlier versions of the Quartus Prime software, you should set the Number of Transceiver Channels to 1 or greater.
Updated 2 months ago
Version 2.0
