Knowledge Base Article
Error: fp_matrix_inv_ii_0: IP generation failed at file discovery, please tell Altera
Description
Due to a problem with the Intel® Stratix® 10 Floating Point Matrix Inverse Intel® FPGA IP in Intel® Quartus® Prime Pro Software version 18.0, you may observe the above error when trying to Generate HDL for the IP.
Resolution
There is no workaround for this problem.
Updated 1 month ago
Version 2.0
