Knowledge Base Article
Error: Failed to process ECO Tcl Script File
Description
You might see this error in the Quartus® Prime Pro Edition Software when using ECO commands in designs targeting Agilex™ 5 devices.
ECO: Failed to process the ECO command at line n of the TCL script
This error occurs because incremental update is not supported.
Resolution
To avoid this error, add the command "eco disable_idat" to the ECO tcl script.
Updated 3 months ago
