Knowledge Base Article
Error: Factory com.altera.sopcfactories.QsysFactory reading xxx.qsys exception com.altera.utilities.altNode.AltNodeException(in-memory string):Premature end of file.(XML)
Description
You may see the error above when open an empty or corrupted file of the xxx.qsys using the Platform designer (formerly Qsys).
Resolution
The available options is to use a previously saved design(before the corruption) or recreate the design from scratch.
Updated 3 months ago
Version 2.0
