Knowledge Base Article
Error: Export Address/Command parity error indicator cannot be used if Addr/CMD parity latency is disabled. Addr/CMD parity latency is controlled in the Mode Register Settings section of the Memory tab (advanced setting).
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 20.3, you may see this error when you turn on the “Export Address/Command parity error indicator” option in the Intel Agilex® 7 FPGA DDR4 EMIF IP.
Resolution
Generate the Intel Agilex® 7 FPGA DDR4 EMIF IP without the “Export Address/Command parity error indicator” option turned on.
Open the IP file ( .ip ) with a text editor and enable the “AC_PARITY_LATENCY” setting with valid values.
Change from:
              <ipxact:value>DDR4_AC_PARITY_LATENCY_DISABLE<ipxact:value>
To:
              <ipxact:value>DDR4_AC_PARITY_LATENCY_4<ipxact:value>
The valid AC_PARITY_LATENCY values are 4, 5, 6, and 8.
Refer to the memory vendor datasheet for more details on the address/command parity latency value to apply.
Then, regenerate the IP with the option “Export Address/Command parity error indicator” turned on.
Additional Information
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 20.4.
Updated 1 month ago
Version 2.0
