Knowledge Base Article
Error: Execution of command "{<quartus_installation>/nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Description
Due to a problem in the Intel® Quartus® Prime Standard Edition software version 20.1 and earlier, you may see this error when you generate a system in the platform designer that includes the Intel® Memory Interface IP for DDR4. This error may happen if you are using an OS build version of Windows* 10 which is older than 18252.
Resolution
To workaround the problem, you can follow the steps below:
  1. Uninstall Ubuntu* 18.04 (if you have one)
  2. Uninstall wsl
  3. Re-install wsl
  4. Download latest Ubuntu 18.04 from Microsoft Store & install it
  5. Execute following commands on Ubuntu shell :
     sudo apt-get update
     sudo apt install wsl
     sudo apt install dos2unix
     sudo apt install make
     sudo apt-get upgrade
This problem is fixed starting with the Intel® Quartus® Prime Standard Edition software version 21.1.
Updated 1 month ago
Version 2.0
