Knowledge Base Article
Error: enable0 input port of SERDES receiver or transmitter atom "rx_0" must be driven by a clock output port of the fast PLL
Description
The ALTLVDS_RX megafunction in the Quartus® II software version 10.0 SP1 incorrectly sets the rx_enable pin to std_logic_vector(0 downto 0) in External PLL mode. The corrrect syntax should be std_logic.
Resolution
A patch is available to fix this problem for the Quartus II software version 10.0 SP1. Download and install Patch 1.114 from the appropriate link below.
This issue is fixed in the Quartus II Software version 10.1.
Updated 4 months ago
Version 4.0
