Knowledge Base Article
Error: dma_0_control_port_slave_translator.avalon_anti_slave_0: master without waitrequest must match parameters and ports of slave dma_0_control_port_slave_translator_avalon_anti_slave_0_agent.av
Description
You will see this error when generating a 64-bit address Avalon® Memory-Mapped Hard IP for PCI Express® design with the Scatter Gather DMA (SGDMA) function.
The error should mention that the SGDMA does not support 64-bit addressing.
Resolution
Do not use the SGDMA function with 64-bit PCI Hard IP addressing. Change the PCI Express Hard IP to 32-bit addressing.
Updated 2 months ago
