Knowledge Base Article
Error: Can't find dependent libraries sGeneric was not found inside Quartus. Please reinstall DSP Builder
Description
When you run DSP Builder standard blockset version 13.1 and 13.1 Arria Edition, MATLAB may generate this error because of an DSP Builder installation problem.
Resolution
To work around this problem, either:
1) Run sGeneric after starting DSP Builder. This call produces an error, which you can ignore, and it initiates DSP Builder to load the required libraries.Run this call every time you start DSP Builder.2) Install Visual Studio VC10 on the PC where you use DSP Builder standard blockset.
Updated 2 months ago
Version 2.0
