Knowledge Base Article
Error: Can't connect to X11 window server using '[hostname:port]' as the value of the DISPLAY variable.
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.3, you may see this error when running the qsys-generate command. This problem occurs when x11 forwarding is not enabled in the Linux terminal you are using.
Resolution
To work around this problem, unset the DISPLAY variable by running the following command in the Linux terminal:
unset DISPLAY
This problem is fixed beginning with version 22.1 of the Intel® Quartus® Prime Pro Edition Software.
Updated 1 month ago
Version 2.0
