Knowledge Base Article
Error: Can't access JTAG chain, Error: Operation failed when programming with the ByteblasterMV download cable
Description
This solution only applies if the Hardware Setup field in the Quartus® II Programmer lists "ByteBlaster" instead of "ByteBlasterMV" or "ByteBlaster II."
To avoid these errors, perform the following steps after installing the Quartus II software:
- Reboot the machine
- Uninstall the sentinal driver
- Browse to the <Quartus II installation directory>/drivers location
- Double click the sentinal driver program, setupx86.exe
- Choose uninstall from the File menu
- Install the sentinel driver by choosing install from the File menu
Another alternative is to program with the USB Blaster download cable, which does not cause this problem.
Updated 2 months ago
