Knowledge Base Article
Error Building Imported Project: 'No rule to make target'
Description
If an application or library project is created with version 9.1 SP2 or earlier (using the GCC 3 toolchain), and you import it to the version 10.0 Nios II SBT for Eclipse using the GCC 4 toolchain, you might see the build error shown in .
make all
Info: Building ../hw_bsp
make --no-print-directory -C ../hw_bsp
make[1]: *** No rule to make target '/cygdrive/c/tmp/verilog_niosII_stratixII_2s60_standard/software/hw_bsp/alt_sys_init.c',
needed by 'all'. Stop.
make: *** [../hw_bsp-recurs-make-lib] Error 2 |
This error can also happen if you import a GCC 3 project to the version 10.0 SBT for Eclipse using the GCC 3 toolchain, and later change the toolchain to MinGW Nios II GCC4.
This issue only affects platforms running the Windows operating system.
Resolution
To avoid this error, follow these steps:
- Edit the application project and library project makefiles and add the inserted code as shown in .
- Right-click the BSP project, point to Nios II and click Generate BSP.
- Clean and rebuild the application and library projects.
# The adjust-path macro
# If COMSPEC is defined, Make is launched from Windows through
# Cygwin. This adjust-path macro will call \'cygpath -u\' on all
# paths to ensure they are readable by Make.
# If COMSPEC is not defined, Make is launched from *nix, and no
adjustment
# is necessary
# Beginning of inserted code
ifndef COMSPEC
ifdef ComSpec
COMSPEC =
endif # ComSpec
endif # !COMSPEC
#end of inserted code
ifdef COMSPEC
adjust-path =
adjust-path-mixed =
else
adjust-path =
adjust-path-mixed =
endif |
Alternatively, install the Altera Complete Design Suite version 11.0 or later.
Updated 2 months ago
