Knowledge Base Article
Error: arch_0: Byte/Pin Swizzling: The input channel number "1" in PIN_SWIZZLE_CH1_DQS0 is greater than the number of channels in the design (0-0).
Description
You may see the error message when you generate Agilex™ 5 HPS-EMIF IP from Quartus® Prime Pro Edition Software version 24.1 . Currently pin swizzle option is not supported yet for 2ch configuration.
Resolution
This will be fixed in future release of Quartus® Prime Pro Edition Software
Updated 1 month ago
