Knowledge Base Article
Error: An unexpected error occurred during Generate: java.lang. OutOfMemoryError: java heap space
Description
You may see the error above when running the Platform Designer system using Intel® Quartus® Prime software version 18.0 and earlier that consumes a large amount of memory.
Resolution
You can increase the maximum memory usage for Platform Designer to generate your design. This can be done either through a setting in Quartus Prime Pro software via Tools->Options->IP Settings->Maximum Platform Designer memory usage; or you can pass along the switch, --jvm-max-heap-size=16g to give
Platform Designer more memory to use if you launch Platform Designer from command line.
Updated 1 month ago
