Knowledge Base Article
Error: add_fileset_file: No such file C:/intelFPGA_pro/21.1/ip/altera/sld/st/intel_st_debug_if/cadence/intel_st_dbg_if_csr_h.sv
Description
Due to a problem in the JTAG-Over-Protocol Intel® FPGA IP, using the Intel® Quartus® Prime Pro Edition Software version 21.1 and 21.2 you may see an error message similar to the following when generating the HDL code with the option Create simulation model= Verilog or VHDL.
    while executing
"add_fileset_file $current_sim/intel_st_dbg_if_csr_h.sv       SYSTEM_VERILOG PATH $current_sim/intel_st_dbg_if_csr_h.sv $attr"
    (procedure "add_rtl_files" line 25)
    invoked from within
"add_rtl_files sim"
    (procedure "sim_callback" line 2)
    invoked from within
"sim_callback intel_st_dbg_if_top"
Resolution
A patch is available to work around this problem for the Intel® Quartus® Prime Pro Edition Software version 21.1 and 21.2.  Download and install the patch from the appropriate link below.
Download patch Intel® Quartus® Prime Pro Edition 21.1 Patch 0.40 for Windows (.exe)
Download patch Intel® Quartus® Prime Pro Edition 21.1 Patch 0.40 for Linux (.run)
Download the Readme for Intel® Quartus® Prime Pro Edition 21.1 Patch 0.40  (.txt)
Download patch Intel® Quartus® Prime Pro Edition 21.2 Patch 0.13 for Windows (.exe)
Download patch Intel® Quartus® Prime Pro Edition 21.2 Patch 0.13 for Linux (.run)
Download the Readme for Intel® Quartus® Prime Pro Edition 21.2 Patch 0.13  (.txt)
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 21.3.
Updated 4 months ago
Version 4.0
