Knowledge Base Article
Error: "933.333" is not a valid memory speed grade
Description
You may see the error message when you generate a UniPHY-based DDR3L IP with a memory device speed grade equal to or higher than 933.333Mhz.
Error: argument to math function didn't have numeric value while executing "expr {double() (( - ) * ( - ) / ( - ))}" invoked from within "return [expr {double() (( - ) * ( - ) / ( - ))}]"
Resolution
This issue is fixed in the Quartus® II software version 15.0.Updated 2 months ago
Version 3.0No CommentsBe the first to comment
