Knowledge Base Article
Error (332000): ERROR: Argument "node_object" is an object filter that matches no objects. Specify one matches only one object
Description
You may see the following error when trying to run <instance_name>_p0_pin_assignments.tcl file when implementing UniPHY based external memory interface IP generated in VHDL:
Error (332000): ERROR: Argument <node_object> is an object filter that matches no objects. Specify one matches only one object.
    while executing
"get_node_info -cell "
    (procedure "is_node_type_pll_clk" line 2)
    invoked from within
"is_node_type_pll_clk "
    (procedure "get_input_clk_id" line 2)
    invoked from within
"get_input_clk_id "
    (procedure "<instant_name>_p0_get_ddr_pins" line 240)
    invoked from within
"<instant_name>_p0_get_ddr_pins allpins"
    (procedure "<instant_name>_p0_initialize_ddr_db" line 13)
    invoked from within
"<instant_name>_p0_initialize_ddr_db <instant_name>_p0_ddr_db"
    invoked from within
"if { ! [ info exists <instant_name>_p0_sdc_cache ] } {
    set <instant_name>_p0_sdc_cache 1
} else..."
    (file "../ddr3/<instant_name>/<instant_name>_p0.sdc" line 186)
Resolution
You need to modify the RTL code in the file <instant_name>_0002.v and make changes to signal declaration for the following signals, these signals are single bit in verilog code but are declared as std_logic_vector in VHDL wrapper for the IP:
output wire [0:0]   mem_ck,        //     .mem_ck
output wire [0:0]   mem_ck_n,      //     .mem_ck_n
output wire [0:0]   mem_cke,       //     .mem_cke
output wire [0:0]   mem_cs_n,      //     .mem_cs_n
output wire [0:0]   mem_ras_n,     //     .mem_ras_n
output wire [0:0]   mem_cas_n,     //     .mem_cas_n
output wire [0:0]   mem_we_n,      //     .mem_we_n
by adding [0:0] you will match the signal declaration to be compatible with VHDL.
This issue will be fixed in the future relase of Quartus II software.
Related Articles
Updated 2 months ago
Version 2.0
