Knowledge Base Article
Error (24297): Cannot use 200G Hard IP location xx and FGT channel location xx as 200G Hard IP is currently not supported with this OPN. If you need 200G Hard IP, please reach out to Intel Field Representative.
Description
Starting in the Quartus® Prime Pro Edition Software version 23.4, the error below will be seen when using the Agilex™ 7 FPGA F-Tile 200G Hard IP datapath, for example when using the PAM4 8x53Gpbs with QSFPDD Serial loopback design on the Nios® V/m Processor:
Error (24297): Cannot use 200G Hard IP location ehip200g_st_x1_7_rx and FGT channel location fgt_q0_ch0_rx as 200G Hard IP is currently not supported with this OPN. If you need 200G Hard IP, please reach out to Intel Field Representative.
Error: Design cannot be programmed onto available F-Tiles because given location constraints are conflicting, or because the design requires more resources compared to what is available on current device
Resolution
Starting in the Quartus® Prime Pro Edition Software version 23.4, the F-Tile 200G Hard IP block is de-featured on existing OPNs with no suffix and “B” suffix. For prototyping use only a patch can be provided to enable compilation and SOF file generation.
Please contact your Intel® Field Representative if you require the patch for F-Tile 200G prototype evaluation on OPNs, not including the C suffix.
Updated 1 month ago
Version 2.0
