Knowledge Base Article
Error (213051): File <filename>.key does not contain key <key>
Description
Due to a known problem in the Quartus® II software version 14.0 and later, you may see this error when using the Convert Programming Files utility or the quartus_cpf command, and the <key> in <keyfile>.key contains upper case letter(s) in the key name.Resolution
To avoid this error, only use lower case letters in the key name.
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 3 months ago
