Knowledge Base Article
Error (210027): Can't use configuration device EPCQL256 with selected programming mode
Description
You may see this error message when compiling an Arria® 10 design in Intel® Quartus® Prime or Prime Pro Edition Software version 17.0 or later when you are not using Active Serial (AS) configuration mode.
The error is caused by the .qsf assignment below, which appears in the .qsf file by default.
set_global_assignment -name USE_CONFIGURATION_DEVICE ON
Resolution
To work around this error, change the above .qsf assignment to
set_global_assignment -name USE_CONFIGURATION_DEVICE OFF
The USE_CONFIGURATION_DEVICE assignment is for AS configuration only.
Updated 20 days ago
Version 2.0
